Keith - I had the same issues with an Onan twin in a garden tractor. Problem turned out to be a failing (weak) coil.
The Onan twin has the plugs connected in series. High voltage goes from the coil to one plug, passes thru the block to the other plug, then returns to the coil via the 2nd plug wire.
By grounding one plug wire, full coil voltage is applied to a single plug rather than being shared. Thus a weak coil may still fire one plug but not both plugs together.
Today's Featured Article - Restoration Story: 1964 JD 2010 Dsl - Part 2 - by Jim Nielsen. Despite having to disassemble the majority of my John Deere 2010's diesel engine, I was still hopeful I could leave the engine-complete with crankshaft and camshaft-in the tractor. This would make the whole engine rebuild job much easier-and much less expensive! I soon found however, that the #4 conrod bearing had disintegrated, taking with it chunks of the crankshaft journal. As a resul
... [Read Article]
Latest Ad:
[More Ads]
