Re: Best way to fix bucket
Posted by trucker 40 on April 11, 2011 at 17:39:26 from (69.152.38.107):
In Reply to: Best way to fix bucket posted by Inno on April 11, 2011 at 07:26:49:
A big bolt or all thread and heat it up draw it back in place.Another way would be to make a tool that you would cut out of a thick plate of steel that would slide over the bent piece.Heat it up and with a long pipe on your thing you made pull it Back into shape.Cut the piece kind of like jaws on a crescent wrench with a long enough piece for a handle that you can slide a pipe over it and put a lot of pressure on it. Probably 1/2 inch thick would do it,but thicker would probably be better.Or Heat and Beat,but that is going to take a lot of beating one something that thick probably.Plus you wouldn't want to batter up the end of that hole or you wont get the pin back in.
