Re: rear brakes won't bleed
Posted by rustred on April 15, 2011 at 08:01:21 from (74.200.18.155):
In Reply to: rear brakes won't bleed posted by farmer boy on April 14, 2011 at 20:40:42:
well for one thing it takes two people to bleed the brakes, unless you have a bleeder hooked to it.just cracking the line will do nothing.first thing to do is remove the bleeders as they are most likly plugged with road grit.use a drill bit and air to clean them out.you need a person to apply the brakes when bleeding. once ready get the person to step on the pedal, then you open the bleeder and close it and watch for air discharging out.then he releases pedal and depresses it again and you repeat procedure till you have only fluid shooting out. your descripion of bleeding lines makes me believe thats why you cant get the air out.dont forget to keep the fluid level topped up.
