Re: How to add fluid to tires??
Posted by DScott on April 19, 2011 at 19:17:55 from (98.193.133.10):
In Reply to: How to add fluid to tires?? posted by Justin SE IOWA on April 19, 2011 at 19:05:35:
Justin,
I use a a sump pump in the bottom of a 5 gallon bucket, pump in the anti-freeze and then finish it off with water. Put the valve stem at the top position so you can release the air pressure that will build up every so often without pushing the fluid back out. This is similar to what you were describing.
