Re: OT Electrical question, drivening me nuts........
Posted by George Marsh on May 03, 2011 at 07:53:22 from (205.188.116.74):
In Reply to: OT Electrical question, drivening me nuts........ posted by Lloyd in South Carolina on May 03, 2011 at 05:52:36:
Use a wire nut and wire the two hot wires together that go to the switch. Use your breaker to turn lights on and off. Get a cheap ammprobe from harbor freight and measure the amps on the light circuit. It is possible you have more than just lights on the switch. It is also possible your switch is located in a high moisture area or a high dust area causing it to fail. Measuring your current will tell the story. You may find you have other loads feeding through the switch.
George
