Re: 1954 wd45 stuck in first gear!
David
01-11-2001 15:17:03
If it is stuck in gear (not frozen) use a flashlite to look into the shift lever hole (leave the trans. cover in place) and use a long screw driver to reposition the shifting slots (term??) so that they are completely parallel to each other. This should put the trans. back into nuetral. If this keeps happening, then the shift level bottom and/or shift tower collar is probably worn and may need to be replaced or rebuilt. This is a common problem with WD's. Shifting very slowly and carefully can help prevent the problem. Also, search the archives as this is a recurring discussion on this board.
