Re: AC B shut down after warming up
steve
06-13-2001 20:54:37
when it shuts down, check to see if you have spark by pulling plug and touching it to ground. Yhrn pull the plug at bottom of carburetor bowl, do you have fuel?? need to narrow it down to one or the other. on the charging, the A terminal of the generator goes to the relay and back to the ampmeter. the G terminal goes to the light switch and then ground. take the G terminal and ground it and see if you get charge, if not push the contacts together on the cut out relay, if neither works the generator is bad.
marge
06-14-2001 01:54:59
 Re: Re: AC B shut down after warming up in reply to steve, 06-13-2001 20:54:37
Thank you for the reply, I will try that and let you know.
RW[OR]
06-18-2001 23:49:05
 Re: Re: Re: AC B shut down after warming up in reply to marge, 06-14-2001 01:54:59
When my B does that I know it's time to clean the oil bath air cleaner. Take the air cleaner off and wash the screen inside.
