Re: AC B shut down after warming up
Glenn(WV)
06-15-2001 07:05:47
As far as the shutdown goes, you might also have a bad coil or condenser. If the coil is bad, the heat from the engine will cause the windings in the coil to open; the engine will miss or die as a result. Both are pretty inexpensive replacement parts. HTH
