Re: Re: 3 point conversion on a CA
steve
12-29-2002 15:18:56
i used a splitter valve (two position) so the tractor hydraulic lever can lift either the blade or the mower, depending on which is "valved in". you are right, when you put it in pto, the mower blades always turn, even when you are using the rear blade, unless you jump the belt off.
