Re: Re: WD45 with WD motor
Sid
07-13-2003 15:12:09
Accordingto the research and info section on this site [ if I am reading it right} in 1953 the first serial number for WD was 131273 the first serial number fo WD45 that same year was 146607 and the first serial for WD45 in 1954 listed is 160389 and the first serial number for WD45 in 1955 is 190993. As I said, if I am reading it right, the tractor would be a WD45 made in 1954.
ACEd
07-13-2003 18:24:21
 Re: Re: Re: WD45 with WD motor in reply to Sid, 07-13-2003 15:12:09
Agree its a 1954 WD45 "chassis", but 226 ci motor for WD45 should start with 45- and should be somewhere around 24000 for serial number to match the chassis. The WD-306959 PA would make it a late 1951 WD 201 ci motor with the higher compression (PA) configuration as motor came from factory.
