Re: a-c 190 diesel
Gordon Chance
07-03-1999 13:14:03
Ray: I agree with Jim that the bushing needs to be replaced. While you have the pump off, be sure to inspect the pump drive shaft for a possible crack. The shaft has a hollow bore for a spring and plunger and if there is a crack it will allow fuel to enter the engine through the bore in the shaft. I have seen this happen one time in my 23 years of working on Allis tractors, so it is not likely but it is worth checking. Be very careful when you install the pump that you don't fold the first seal back and allow fuel to get into the engine again. Good luck. Gordon
