Re: I have a WD45 just did a engine overhaul and i
Adam chytil
08-26-2005 07:19:13
i found the problem it was to do with the rocker arm but it was because the new head gasket was 1 mm thiner so that messed the setting up on the rocker arms thanks for your help
Dick L
08-26-2005 09:23:10
 Re: I have a WD45 just did a engine overhaul and i in reply to Adam chytil, 08-26-2005 07:19:13
Good deal. The rocker/ tappets/ space between the rocker and valve stem should be reset every time the rocker arm assembly has been removed and then rechecked after the engine has run for a short time. I go back thru and recheck torque on the head bolts and rocker settings after no less than 1/2 hour of run time. I cut my teeth on six cylinder chevys and check and reset rocker arm settings at a slow idle. Still do. My feeler gage and shirts show it.
Hurst
08-27-2005 09:53:58
 Valve adjustment while running??? in reply to Dick L, 08-26-2005 09:23:10
I have heard of people doing the adjustment running, but never seen it or heard how it was done. Just out of curiosity, could someone explain this to me? Thanks
Hurst
