Re: 180 STEERING
Hurst
03-03-2007 06:13:04
I would start with checking to make sure that the lines are hooked up correctly. It could be that you accidentally switched one or two and it is making it a motor now. Also, how far did you disassemble it? Did you get so far as to taking all the "guts" out of the inside? If so, it is possible that something got put back in upside down or in the wrong place. I have taken apart a ford steering motor for a 6610, and there are a few parts that can be put back incorrectly pretty easily, so I would assume it would be the same for the 180.
Hurst
