this guy says this allis came with a 3 pt from factory
arthur ward
07-14-2007 18:48:13
third party image
what do you guys think?
Mike Fox
07-25-2007 07:03:47
 Re: this guy says this allis came with a 3 pt from factory in reply to arthur ward, 07-14-2007 18:48:13
Please tell me how you uploaded the picture.
Thanks.
patsublett
07-15-2007 10:13:42
All tractor manufactures except Ford & Ferguson began installing 3 points about the same time, after Ferguson's patent right ran out. AC's hitch was an attempt to copy Ferguson as close as possible without violating Ferguson's patent. Your hitch is an aftermarket.
old
07-14-2007 20:05:04
That is an after market set up. Could have been dealer installed but still its after market. Sort of like the sherman or howard trannys in the fords.
ohio
07-14-2007 19:13:59
they did come with three point. one in the snap coupler bell, and two in the hands on the lift arms! worked quite a bit better than harry fergesons setup, but implements can be hard to come by. that setup in the pic, however, is most certainly not the way it came from west allis.
arthur ward
07-15-2007 06:49:22
 Re: this guy says this allis came with a 3 pt from factory in reply to ohio, 07-14-2007 19:13:59
what do you guys thing its worth? just a paint job there. no oil burning either.
thanks
ohio
07-15-2007 06:59:38
 Re: this guy says this allis came with a 3 pt from factory in reply to arthur ward, 07-15-2007 06:49:22
what are them, 16.9's? if rims, radiator, ect. are good, maybe $1000- $1500 around here.
