Re: d 17 power director
TexasAllis
09-11-2007 06:43:15
Dave,
You can try adjusting the bolt at the bottom of the high/low shifter if there is any adjustment left. That will let the shifter snap over further. If that does not work you will need to shim the clutch pack. You will have to split the tractor to do that. A good manual will explain how to shim the clutch.
