Re: 1956 400 standard
Doc Larry
11-08-2006 17:02:17
When I had a similar problem, I found a broken detent spring in the shifting mechanism.
You can check to see if the excess play is in the pin in the shift lever. If it"s not there, you"ll need to pull the transmission cover to get to the forks and rails to see where the problem is.
Larry
