'45 VAIW in OD Green
Dan Bear Kelley
09-09-2007 17:08:57
It always has been common to paint a tractor to match what work it will be doing. So, paint it as you see fit. It is your tractor, and I don't think color will change the value of the tractor one whit. My personal opinion is that it will be more unusual to be painted as a DPW tractor in yellow. My 2 cents
I'm working on a 1945 VAIW that had many layors of paint on it. Flambeau red was at the bottom, with a thick brushed-on coat of OD green, followed by black and finally yellow. I know the Army Air Forces bought a bunch of VAI's and VAIW's to use as aircraft tugs. This one will be going back to the Commemorative Air Force for that same work, when I get it done. However, the hangar in which it will be going houses mostly Navy aircraft, so I will be painting it Navy Grey with a black star and a black "U.S. Navy" on the hood.
