Re: 430 Case Injector Pump Problem
Gary
02-05-2003 18:03:12
A quick word of free advice and that may be more than it's worth. BEFORE removing your pump, turn it over til the timing mark in the pump is in line. Makes it a whole lot easier when you get ready to put the pump back on. When you get ready to bleed the injector lines, pull the intake hose off and place your hand over the intake while you are spinning it over. After about one turn without any intake, it will free wheel while the lines are bleeding, keeping your starter from getting hot and running your battery down.
