Re: 2
Case SC Questions
Mike Schotte
03-05-2003 17:08:40
Hi Myron,
From the CASE library- (grin)
HEAT REGULATOR VALVE:
"Always close the radiator shutters completely when starting a low-cost fuel equipped tractor. Set the manifold heat regulator valve in the HOT position by pushing the lever to the right- (towards the rear of the tractor)- as far as possible.
STARTING SWITCH:
The switches seem to be the same part number for both the "S" series and "D" series- but the posts are listed as having different lengths. Here's both of the descriptions-
The "S" series starter switch is Part # 04981AB, (screw 1/4" X 1/2" rhd. mach., N.C. thread. Nut- 1/4" hex., light, N.C. thread. Washer- 1/4" std. lock.)
The "D" series starter switch is Part # 04981AB, (Bolt, 1/4" X 3/4" round head stove, with nut. Washer- 1/4" standard lock.)
Talk to you later, -Schotte
C. Amick
03-06-2003 08:30:55
 Re: Re: 2 - Case SC Questions in reply to Mike Schotte, 03-05-2003 17:08:40
Do the instructions say when the valve should be switched back the other way, off the the hot setting. I think it has at least 5 different positions to choose from. Perhaps the position to be selected is based on engine temperature?
