Re: 1949 case SC
Steve from PA
10-13-2004 09:14:17
Why would you disengage the clutch? Is there a chance of it sticking? I have a '51 SC and although it's kept in the barn, I was leary of setting the parking brakes because of the possibility of the discs galding to the friction plate. I suppose I could chock the wheels instead. Please advise. Thanks, Steve.
C. Amick
10-13-2004 09:30:46
 Re: 1949 case SC in reply to Steve from PA, 10-13-2004 09:14:17
There is a chance of the clutch plate sticking if it sets for a long period of time. But he biggest reason I disengage the clutch is to release the pressure plate so the springs don't stay compressed. I don't set the brake. I just leave a piece of a 2x4 laying on the floor of the tractor shed. Some may think this is not needed. I didn't read anything that said to do it.
L.Lamp
10-15-2004 19:21:46
 Re: 1949 case SC in reply to C. Amick, 10-13-2004 09:30:46
The clutch in a '49 SC is the over center type and there are no springs to compress. It does not hurt the clutch to be engaged while it is parked. If you are using good quality detergent oil, and don't let it get filthy dirty between changes it will be OK. Use it once a year and you won't have a problem.
