Re: 2294 Power Shift
DKase
01-11-2006 05:51:04
I had the same problem on a 2090. The C-3 valve was sticking. It is the second plug from the front of the control valve going up from the bottom. Remove the plug, spring, and spool. Polish the spool with emery cloth and make sure it moves freely in the valve. If it still sticks you might have to find a 9/16 ball and tack weld it to a bolt and push it up into the valve to clean up the bore. Install the spool, spring, and plug. Hopefully it will work better as mine did. Ten minute job! Good Luck DK
