530 DIESEL CASE HELP
gary case
03-30-2005 14:15:48
BUYING THIS 530 BUT THE REAR END FLUID IS PERTY MILKY,YELLOW LOOKING. IS THIS WATER AND A BIG PROBLEM OR JUST A FLUID CHANGE? BEEN SITTING OUTSIDE. LOADER WORKSUP AND DOWN BUT THE TILT IS SLOW TO NOTHING. SAID IT WORKED FINE AND EVEN HAS DOWN PRESSURE. CHECKED HYDRO FLUID (NOT RUNNING) AND SHOWED FULL. IS THERE ANOTHER PLACE TO CHECK? HAS TRACTOR HYDR CONTROLS AND ONES ON LOADER.IS THERE ANOTHER WAY TO MAKE THIS TO OPERATE ONLY THE LOADER? NOW YOU HAVE TO HOLD ONE DOWN AND CONTROL THE OTHER. THANX FOR ANY HELP GARY
wayne2
04-02-2005 18:20:30
 Re: 530 DIESEL CASE HELP in reply to gary case, 03-30-2005 14:15:48
Gary, Bucket cyl. can be rebuilt, but use loader for a while if pump is bad all of it will slow down and thats $$. Luck
