Re: 1950 case VAC 6 volt to 12 volt conversion
F-I-T
11-26-2005 13:00:28
third party image
Paul:
There are lugs on the base ala a conventional modern battery. I built a square tubing frame, notching it out for the lugs and then bolted that down. It's pretty secure.
Frank
Paul f
11-27-2005 06:08:43
 Re: Thank you in reply to F-I-T, 11-26-2005 13:00:28
I knew you would have a very tidy system
'56 VAI Guy
12-01-2005 19:35:39
 Re: Thank you in reply to Paul f, 11-27-2005 06:08:43
Paul. What kind of mowing system are you using? I recently purchased a mid '50s VAI and also bought a 5 ft King Cutter Mower for it.....the price was right. I tested it out before I put it away and the tracor seems to have enough HP for it. I will be mowing about 10 acres/year with it (just knee high grass). What do you think?.
Mark
