Re: Oliver OC4, OC46 DOZER INFO
polk
06-10-2002 06:38:41
Adam: Get onthe Cletrac.org website; check the brochure illustrations; one is of the OC4 and OC46. The spec sheet has all the info on both the gas and diesel models.
Have my eye on an OC-46-3, Series B. Owner wants to sell, wants too much. Only defect I see is LH front idler outer rim edge and hub is rubbing on frame...outer bushing or bearings could be shot; runs good otherwise. The Cletrac website will tell you a lot you want to know.Good luck. PC
