Thanks Wardner, I diden't know
gots-2-go
02-18-2007 19:03:31
Thanks for the quick reply Wardner, I did not know about the idler gear in the 9 series.
Guess that throws this one in the trash.
Does the 6 series have the idler gear too?
gots-2-go
Wardner
02-18-2007 19:20:44
 Re: Thanks Wardner, I diden't know in reply to gots-2-go, 02-18-2007 19:03:31
No, that's my point. The gear layouts between the gas 6 and gas 9 series are different. It came as a surprise to most of us.
No idler on the 6 series gas motors. Idler on all 9 series and 6 series diesels.
I suspect that Dave will confirm later.
D Slater
02-19-2007 10:04:07
 Re: Thanks Wardner, I diden't know in reply to Wardner, 02-18-2007 19:20:44
Wardner, another bit of information, not all MD and WD9 had the same bolt pattern where pump would bolt up. Even though they turn same direction not all pumps will work even between same size tractors. M&W didn't make one pump to fit all for the diesel and W9 series like they did on M. Most later MD, WD 6 and 600 used the same pump though,also 9 tractors if the magneto or distributor drive has a part # 261206 R1.
