Re: W.F. Hebard Shop Mule
Haas
02-26-2007 14:05:47
The difference between the A-14 and the A-21 is not much. Differences are minor and not consistent. Side by side, you won't see much unless you look real close and even then, it could be some change made after it was built. The A-14 came first, and was followed by the A-21. There are is much difference between older and later A-21 mules as there is between the A-14 and the A-21. This is an opinion, not fact, but I think they just changed the model number to end the confusion between the A-14 and the A-14V.
