Good eye.
A. Bohemian
03-24-2007 11:13:50
Actually, you've done three compression checks:
Quote: "My model A Farmall runs pretty good, but I can detect a slight miss-fire (in one cylinder I believe). When idleing there is a detectable "puff-back" in the exhaust tone. If I lug the engine slightly, say in 4th gear, the miss-fire is more noticeable to me."
I think you have low compression on one or more cylinder(s), and you have sucessfully diagnosed the problem with this tractor, using your ears and a little careful observation; I think you can confirm it by doing the individual compression checks.
I'm sorry it might need engine and/or valve work but you've done a good job figuring it out!
