Re: What tractor does tihs plow fit??
georgeky
04-16-2007 12:03:26
Old I don't have all my old plows at home to check numbers, but if you had a picture I may be able to help.
old
04-16-2007 14:18:52
 Re: What tractor does tihs plow fit?? in reply to georgeky, 04-16-2007 12:03:26
Ya don't have any at this time. The main beam has one hole where a pin would go at the front end of it. Then close to the back of the plow theres a cross bar with 2 holes about and inch around and spaced about 18 inch wide. That whole set up is about centered with the main beam. Don't know if that info helps or not. Also looks to be a 14 or 16 inch bottom
