tires on m
james braley
04-24-2007 13:33:20
have 13.6-38 on my m what should be the psi. btw i hope i got that tire size right its one step up than the normal m,
georgeky
04-24-2007 18:06:05
 Re: tires on m in reply to james braley, 04-24-2007 13:33:20
They use to claim no more than 12 pounds. That will vary depending on what you are doing. I tug pull a little and let them down to 6 or 7 pounds for that. If they have to much it will cause premature wear if ran on the road much. The same is true if they are low on air pressure.
John M
04-24-2007 14:08:44
third party image
Running 15 in my 13.6s
Fluggie in Ia
04-24-2007 13:50:41
I have always run about 16 to 17 lbs on my standard size tires. I would guess you could lower it by about 2 to 3 lbs with the larger tire and still sit squarely on the ground! I assume you went with a wider rim as well?
neblinc
04-24-2007 13:47:58
Here is a thread on it.
Randy
