130 Fuel line
chad504
06-06-2007 06:40:49
Since I have removed and replaced my fuel tank, i have a leak where the line enters the sediment bowl. I was going to stop and get new line and compression fittings on the way home from work, but I forgot to grab the pieces. What size is the copper line, and what size are the threads on the fittings?
Bob
06-06-2007 08:13:30
 Re: 130 Fuel line in reply to chad504, 06-06-2007 06:40:49
Does the compression fitting screw INTO the sediment bowl, as it does on MANY of these old tractors? (IF the setup is still "as original"?
If so, you need 5/16" steel line and the part number for the fitting is in the post linked below:
El Toro
06-06-2007 07:56:03
If you go to your local Case/IH dealer they can look up the correct size gas line and fittings.
I would think it would be 1/4" or 5/16" tubing.
Is it a copper or steel gas line? Hal
chad504
06-06-2007 08:01:34
 Re: 130 Fuel line in reply to El Toro, 06-06-2007 07:56:03
It's copper
chad504
06-06-2007 10:31:55
 Re: 130 Fuel line in reply to chad504, 06-06-2007 08:01:34
Yes it does, screw into the sediment bowl. I want to replace that also, as it has been rounded off by previous attempts at leak prevention. I don't think there are any splits in the bowl assembly though. Th gas seems to follow the line straight to the lowest point and drip, with no wet spots anywhere around or under the bowl.
