Re: Re: Re: is it possible to get a 450 under 6000 lbs.
TP from Central
07-24-2002 06:36:41
I have done alot of tractor pulling over the years and am wondering about your approach.....One thing you have to understand about older Farmalls is that they do not pull well bare at the lowest weight class you can get them into..... Our SM weighs right around 5500 lbs. and we don't start pulling until the 6500 lbs class. It is almost a guarantee that you are going to get beat by a Putt-Putt at the lowest class, because most of your weight is up front...The approach I would take is instead of taking off, put on....I would leave the fast hitch on and put a piece of angle iron across it...the put a weight bar under the belly, and the one up front. I would start at 6500 and run up to 10,000 or 10,500(what ever your club has)...Just the secret to the equation is having enough suitcase weights to do the job :-)
You should(?) dominate the 7000 thru 8000 Lbs. classes if your weight and tires are up to the matter.....
jason zang
07-29-2003 19:55:36
 Re: Re: Re: Re: is it possible to get a 450 under in reply to TP from Central PA, 07-24-2002 06:36:41
could anyone please tell me aproximately how much a farmall 450 weighs unweighted minus the fast hitch, live powertakeoff power adjust rear wheels and any weights. i am interested in starting pulling and would like to know how much the tractor weighs. i am not sure i would want to pull it any higher than 9 or 10 thousand pounds i don't want to snap the torque. if anyone has any advice please contact me via e-mail ASAP at cowboyzang@yahoo.com any help would be greatly appreciated.
Hugh MacKay
07-24-2002 19:16:06
 Re: Re: Re: Re: is it possible to get a 450 under 6000 lbs. in reply to TP from Central PA, 07-24-2002 06:36:41
Quite true, I saw a Super M pulling in the under 6000 lb. class two weeks ago. He was soundly beaten.
