Is this possible?
Scott
10-21-2003 14:24:14
Guys, I'd like to add hydraulics to my '47 A and was wondering if could just swap my block out for a Super A block. This would give me the boss cast in the block for a pump. Would this bolt up and would my engine internals fit right in a Super block? I'm thinking they should but would really like to hear from some experience out there. Don't like to assume too much! Thanks
Hugh MacKay
10-23-2003 17:40:27
 Re: Is this possible? in reply to Scott, 10-21-2003 14:24:14
Scott: Remember, the engine block is not the only casting different on a A to a SA. The torque tube is also different. Haas said it all, it will be less expensive to buy a SA
FarmallH42
10-21-2003 18:59:39
Here, try this:
Adding hydraulics to a Farmall A without destroying the originality.
Haas
10-21-2003 18:30:23
Unless your A is special to you, likely easier and cheaper to sell your A and find a good Super A to buy to replace it.
