Re: painting rims with tires mounted
Ron in Nebr
10-22-2003 21:32:15
A trick I heard was to smear a thin coat of Vaseline on the tire sidewall, then when you're done painting you can just wipe it off and the tire will be clean.
Slowpoke
10-23-2003 01:35:42
 Re: Re: painting rims with tires mounted in reply to Ron in Nebr, 10-22-2003 21:32:15
It also works good on equipment tags, using an artist's paint brush.
bindernut
10-22-2003 23:17:54
Saw a guy painting a flatbed once. Used this method, substituting grease for vasoline, to keep paint off of the rims & the lights also. Worked well.
