Re: Shipping to our Friends in Canada
harley1983
08-24-2004 19:30:03
Hey Nebraska Cowman, now that you brought it up, I have a farmall H with a 6-volt generator and negative 6-volt battery, and a magneto, and it would have to be a 6-volt coil inside the cover in front of the mag. My question is, can this be converted to 12-volt by adding the alternater, battery, or do I have to start over and go from front to back with new 12-volt stuff. I have switched a hundred systems with a one wire alternater and battery, but never one with a mag before. Thanks, Allen
MN Scott
08-24-2004 20:44:21
 Re: Shipping to our Friends in Canada in reply to harley1983, 08-24-2004 19:30:03
A mag generates its own power. There is no connection to the electrical system. One wire runs from the mag to the kill switch that grounds out the mag when the switch is pushed in.
Harley1983
08-25-2004 22:35:14
 Re: Shipping to our Friends in Canada in reply to MN Scott, 08-24-2004 20:44:21
Great, thanks. I guess you"re right, I never thought that far ahead, but theoretically you can have two different voltage systems here can"t you. 12-volt for the starter, 6-volt from the mag to the engine. Cool, thanks, Harley
