international 300 u
randy
12-17-2004 13:40:07
HELP The pto on my tractor will only disengauge if I hold down hard on the lever ... any suggestion on where to start with repair would be helpful Thanks
Unreserved dick
12-17-2004 18:48:10
 Re: international 300 u in reply to randy, 12-17-2004 13:40:07
If you've got the independent PTO, all you probably need to do is tighten up on the brake band. The 300U IPTO adjustment was discussed on a thread recently - if you follow the link below, hopefully you'll find that discussion.
Loren
12-17-2004 18:38:27
Is it actually not disengaging or is like mine that turns because of the stiff fluid? With the lever in the disengaged setting and the tractor turned off how hard is the pto to turn? Mine turns just about as hard as I can pull by hand, enough to start hurting a bit.
