Re: 140 with 1 bottom plow and single point fast h
Djp
03-15-2005 17:25:57
Hugh,
Yes, I have the linkage from the rockershaft to the front of the hitch. I do not know the model of the plow, but it is a 16". It came with this 140 from the dealer. I do have the leveling crank on the left. I am missing a couple of the threaded thimbles that go on the stops of the control handles. Anybody sell them? I've been putting off making them for 2 years now...
Dan
Hugh MacKay
03-15-2005 17:53:42
 Re: 140 with 1 bottom plow and single point fast h in reply to Djp, 03-15-2005 17:25:57
Dan: Ramon has just saved me a whole lot of typing. Good to see he listened then went out and got his own personal experience, which by the way is all you need now. Make note of the advice I gave to Bill on tractor wheel tread setting for the single bottom plow.
The other item which can make you much happier with your plowing and this applies to all. Keep your wear parts replaced, most of the poor plowing I see is done by worn out points, shins and landsides.
To all of you stick with Ramon's idea of staying with the two bottom plow. I know it pulls hard but those little tractors are up to it. You know the old saying the bigger they are the harder they fall, it applies to tractors, as well.
