Re: Farmall A with exhaust lift
gene bender
02-17-2006 10:37:40
They must have made tons of them as it is not uncommon to see parts of the linkage still on the tractor. Bracket is still on the throttle or even the linkage mounted below the gas tank. I have some on As and Bs also have a BN-187 plow B-187 plow cults for A and B and BN Veggie cult for an A all exhaust lift can also make them hand lift if needed. The cycl was mounted different places for different implements as they had planters front and rear,middlebusters sickle mowers that used the system. They are not rare.
Dave H (MI)
02-17-2006 11:27:58
 Re: Farmall A with exhaust lift in reply to gene bender, 02-17-2006 10:37:40
third party image
Here is a picture of the most common sign that an exhaust lift was once on an A or B. This is the only part left on our B from the exhaust lift. Gene is a great source of info on these as are a few others here. There is also a copy of Red Power you can order from their website which has a good article on the exhaust lift. September/October 2003 has the article by Jim Becker. Recommended to me by the author, it was a great resource. It has the schematic from the owners manual, but I can send you that also if you need it. HTH....Dave
