Wiring harness for DelcoRemy 10si alternator
Bud Nolan
04-21-2006 21:27:41
I own a Farmall 230 and want to install a Delco-Remy alternator.
Does anyone have a wiring diagram?
Please send installation instructions.
Bud
Lottsburg, VA
jeffalex2
04-22-2006 05:08:33
 Re: Wiring harness for DelcoRemy 10si alternator in reply to Bud Nolan, 04-21-2006 21:27:41
I used Bob's 10si diagram on my Super M, but replaced the light bulb with a diode...I re-wired the whole tract and made my own harness...took about 2 hours...works like a charm!!!
John T
04-22-2006 05:04:20
Bud, Heres how I wire a GM 10SI Alternator and remember, it requires NEGATIVE GROUND !!!!! !
The big rear main output alternator terminal goes to the wire that used to be connected to the BAT terminal on the Voltage Regulator or Cutout Relay. HOWEVER if that wire wasnt already upgraded, when I convert from a Genny to an Alternator, I replace that wire with a 10 Gauge and it runs from the alternators main output up to the LOAD (NOT to battery/starter) side of the ammeter. I also replace/use 10 Gauge from the ammeters other SUPPLY terminal to the battery/starter.
The little side number 2F Voltage Sense terminal gets connected (use a short 14 jumper wire) right up to to and with the big side terminal just mentioned.
For the little 1R side Excitation terminal, run a 16 or so gauge wire from the ignition switches IGN (which is HOT ONLY when ignition is turned on) terminal and in series with it place a 10 ohm 5 watt current limiting resistor (dont really need that much wattage power rating, but they are heavy duty built and easy to wire). Then in the rare event the tractor continues to run cuz of alternator backfeed when the ignition is switched OFF, I add in series a 5 amp 50 PIV minimum Diode. The diode must be wired with negative cathode end to the alternator and positive anode end to the switch. Again, the ratings are not that exact but about any diode over a few amps and 50 volts or so works.
Dont forget to change the battery to negative ground and the coil needs to be wired so the negative goes to ground via the distributor points and the positive gets power from the ignition switch and you have to reverse ammeter leads also if your just now changing polarities.
Good luck Ol John T in Indiana
Bob
04-21-2006 23:48:55
Here's some generic 10SI alternator information, and a link to BobM's diagrams, whre you should be able to find one workable for your tractor.
