Order Farmall Cub Parts Online
Re: Farmall cub battery draining
Bus Driver
06-27-2006 03:54:08
My test procedure is to remove the grounding cable from the battery and use a voltmeter between that cable and the battery terminal. Any drain will produce a reading on the volt meter. Disconnect one thing at time to discover the problem. Once we washed a tractor and next morning that battery was discharged. This test procedure discovered that the insulator on the pull-rod starter switch was saturated with water and conducting a bit over 1 volt drop. We replaced the switch.
