Re: grease on face of throwout bearing?
Fromjb2
07-04-2007 17:42:52
Hi, there should be a spring on the clutch pedal to hold the clutch pedal up so the throwout bearing doesn't contact the PP fingers when the clutch is released. The spring is probably broken or missing. It connects to a support under the batter box and then to a hole in the clutch pedal mechanism.
JimB
