Timing Troubles!!!!!!
bigslickone
12-05-2007 18:46:26
I am a new Super M owner and I was messing with stuff that I shouldn't have been and now I have a much bigger problem then when I started. I was wondering if there is a way to fix the timing without going trough all of that stuff? I don't have access to anything to lift up the front of it and no building to do it in. Oh and I live in Iowa in the middle of the winter. Any help would be greatly excepted. Thank You All Greg
Nat 2
12-06-2007 13:59:25
 Re: Try this... in reply to Andrew Z, 12-05-2007 18:46:26
Isn't TDC a common acronym for engines in general? Diesel engines need to be timed against TDC, top dead center, too.
karl f
12-05-2007 19:08:07
 Re: Timing Troubles!!!!!! in reply to bigslickone, 12-05-2007 18:46:26
unfortunately, if you messed something up bad, you probably have to start from scratch, which really isn't that big of a deal, just more steps.
tell us the previous symptoms and what you have done and what's going on now.
i've done alot on our 400 and others in the winter outside. I even changed the hydraulic pump (which meant r & r of distributor) while it was snowing! just follow instructions in I& T manual carefully. you'll do fine.
karl f
Chuck's Repair
12-05-2007 18:57:19
Are you talking about valve timming or distributer timming? You don't have to lift the tractor to time the distributer to the engine and I don't think you are talking about valve timming because you would have had to take the front timming cover off and to do that you would have had to raise the tractor and removed the front boolster.
bigslickone
12-05-2007 19:03:02
 Re: Timing Troubles!!!!!! in reply to Chuck's Repair, 12-05-2007 18:57:19
I have messed with the distributer and turned it quite a few times in all differant directions. But no I have not removed the camshaft gear cover.
Bob
12-05-2007 19:06:01
 Try this... in reply to bigslickone, 12-05-2007 19:03:02
Check out the thread linked below, from only a day or two ago. The same basic instructions will apply to your tractor.
bigslickone
12-05-2007 19:12:56
 Re: Try this... in reply to Bob, 12-05-2007 19:06:01
Thank you and I will try that. I am new at working on gas engines, I was a deisel mechanic in the army but this is a new ball of wax for me. What does TDC stand for??
Roadhog
12-05-2007 20:01:13
 Re: Try this... in reply to bigslickone, 12-05-2007 19:12:56
TOP DEAD CENTER
City-Boy McCoy
12-06-2007 02:54:36
 Re: Try this... in reply to Roadhog, 12-05-2007 20:01:13
Pray for our military.
GordoSD
12-06-2007 13:15:22
 Re: Try this... in reply to City-Boy McCoy, 12-06-2007 02:54:36
Well I'm sure he knows FUBAR
Gordo
georgeky
12-06-2007 07:28:04
Mike, this is a little off topic, but I saw a rerun of the Late Show the other night with Bill Clinton on it, He was going on about how bad we needed to rebuild our military. He was the knothead that dismantled it. When I was on active duty during the Reagan years we had 18 full combat divisions in the army alone. Clinton cut that to 10, and now has the nerve to lay it on someone else. Just an soldier ranting. GOD BLESS OUR SOLDIERS, MARINES,SAILORS,AIRMEN, AND ANYONE ELSE IN HARMS WAY.
agpilot
12-06-2007 09:22:54
 Re: Try this... in reply to georgeky, 12-06-2007 07:28:04
Hello George: Ahhhh... don't need political bashing do we? agpilot ( I had enough of that during the 60's)
georgeky
12-06-2007 12:45:39
 Re: Try this... in reply to agpilot, 12-06-2007 09:22:54
Not really political bashing, just concerned with the demands placed on our youth. I could care less about politics in general.
