Re: Switch
gene bender
02-08-2008 20:32:50
Yes the sw does need to be grounded. I use an OHM meter to check go to ground cable to sw to check.You do have a wire running from the field on the gen to the sw dont you for hi-charge. By the way TOM the TEA is under snow now and cant wait until spring getting awful thirsty for some as a dummy forgot to dry some last fall.
Tom Windsor
02-08-2008 22:32:49
 Re: Switch in reply to gene bender, 02-08-2008 20:32:50
Gene
Get back with me at twindsor@aol.com and let me know how your "free" tractor came out? Yep the "tea" was refreshing, first time I ever tried it.
tw
