Re: Switch
RustyFarmall
02-09-2008 06:10:15
No, that is wrong. If you are using a generator cut-out, you need the 4 position switch. Low charge, high charge, dim lights, and bright lights. The 3 position switch is for a voltage regulator set-up. Off, dim lights, and bright lights.
