Re: farmall h wont run
Chuck46
03-09-2008 20:33:37
Wellsy, Do you have battery distributer or magneto? The points should be set at .020 for a battery, .013 for a magneto. Plugs at .025. Is it timed right? Good luck, Chuck
wellsy
03-10-2008 05:11:16
 Re: farmall h wont run in reply to Chuck46, 03-09-2008 20:33:37
i have the vertical delco distibutoron this tractor i also checked the points and it was .20
Patrick Martin
03-09-2008 20:37:02
Check the coil. Just recently I had one that failed and tested perfect but would not send enough juice to the distributor.
