Re: A cylinder 2 and 3 not firing
1fortyfanatic
05-11-2008 16:15:37
Just FYI, you might want to consider checking around the manifold while it is running to see if the gasket there is possibly a problem. If the manifold gasket on an A is like my 123ci Farmall 140, then the manifold has intake and exhaust side by side. And if the gasket has blown between almost any two of the ports, then you could be getting exhaust in the intake of the neighboring cylinder, in which case, valves will not function properly, and plugs would probably look dry. Be advised though, that if you pull the manifold, you'll probably lose one or both of the old gaskets, so order new ones before you ever pull it. Case / IH dealers can order these gaskets for you, and have the shipped to your house in 3-5 days.
Good Luck
Dave
1fortyfanatic
05-11-2008 16:18:26
 Re: A cylinder 2 and 3 not firing in reply to 658834, 05-11-2008 16:15:37
Oh, and the above could cause screwy compression readings.
Dave
teddy52food
05-11-2008 17:39:08
 Re: A cylinder 2 and 3 not firing in reply to 1fortyfanatic, 05-11-2008 16:18:26
Please explain to me and the rest of us how a leaky manifold gasket would cause screwey compression readings????? ?
ih560
05-12-2008 12:46:09
 Re: A cylinder 2 and 3 not firing in reply to teddy52food, 05-11-2008 17:39:08
If you will have a look at this other quote here,
teddy52food said: (quoted from post at 17:39:08 05/11/08) Please explain to me and the rest of us how a leaky manifold gasket would cause screwey compression readings????? ?
I am not the only one who does not see any relelvance to your post. I am trying to help the original poster by telling him what is more than likley wrong with his tractor rather than some crazy and impossible theory. Just trying to keep him from chasing his own tail here.
I really hope that the poster figures his tractor out.
ih560
05-11-2008 18:59:33
That doesn't really make any sense to me either.
