Re: A cylinder 2 and 3 not firing
1fortyfanatic
05-11-2008 16:18:26
Oh, and the above could cause screwy compression readings.
Dave
teddy52food
05-11-2008 17:39:08
 Re: A cylinder 2 and 3 not firing in reply to 1fortyfanatic, 05-11-2008 16:18:26
Please explain to me and the rest of us how a leaky manifold gasket would cause screwey compression readings????? ?
ih560
05-12-2008 12:46:09
 Re: A cylinder 2 and 3 not firing in reply to teddy52food, 05-11-2008 17:39:08
If you will have a look at this other quote here,
teddy52food said: (quoted from post at 17:39:08 05/11/08) Please explain to me and the rest of us how a leaky manifold gasket would cause screwey compression readings????? ?
I am not the only one who does not see any relelvance to your post. I am trying to help the original poster by telling him what is more than likley wrong with his tractor rather than some crazy and impossible theory. Just trying to keep him from chasing his own tail here.
I really hope that the poster figures his tractor out.
ih560
05-11-2008 18:59:33
That doesn't really make any sense to me either.
francoisc27
05-11-2008 16:22:36
 Re: A cylinder 2 and 3 not firing in reply to 658834, 05-11-2008 16:18:26
El Toro said: (quoted from post at 18:47:22 05/11/08) Take a look in the radiator and see there's bubbles when the engine is at an idle. Did you adjust all the valves to .017" cold? Hal
I'll check the bubble thing, but no I haven't touched the valves yet other than when I first got the thing I could'nt get compression on cyl #1 an I found out the pushrod fell out from under the rocker arm. I just pushed it back in and had compression again.....
Francois
