Re: A cylinder 2 and 3 not firing
1fortyfanatic
05-11-2008 18:55:43
Well teddy, I first want to state that I am no expert, certainly not even on most of you guy's level of experience, but here was my thinking. I just felt that it was theoretically possible that a leaking gasket over time could cause improper valve function when it leaks exhaust into an intake, potentially even valve system damage. Now we all know that damaged or malfuntioning valves can cause real problems to efficiency of the compression stroke, what with air escaping from partially closed valves, and it might be this damage which could cause readings to show low or fluctuate.
Now, while the possibilty of such is pretty remote, nonetheless, the operation of the valves is a very precise timed requirement of proper operation. Should valves be even partially open on the compression stroke, the reading you would recieve in a test, would be lower and not necessarily a reflection of the piston or rings condition. And if as he said, there were alot of missing gaskets / neglect of this engine, then damage from a bad gasket is in fact possible, while not real probable.
:roll:
1fortyfanatic
05-11-2008 18:59:02
 Re: A cylinder 2 and 3 not firing in reply to 658834, 05-11-2008 18:55:43
You're absolutely right Dustin. Unless ..... nah, forget it.
ih560
05-11-2008 19:06:14
 Re: A cylinder 2 and 3 not firing in reply to 1fortyfanatic, 05-11-2008 18:59:02
Cylinders 2 and 3 share an exhaust port, but an engine will run and not miss even without exhaust manifolds, so that would not cause it to miss. The only thing running without manifolds will do is eventually burn the valves due to the heat not being carried away from them through the manifold.
