Re: A cylinder 2 and 3 not firing
1fortyfanatic
05-11-2008 18:59:02
You're absolutely right Dustin. Unless ..... nah, forget it.
ih560
05-11-2008 19:06:14
 Re: A cylinder 2 and 3 not firing in reply to 1fortyfanatic, 05-11-2008 18:59:02
Cylinders 2 and 3 share an exhaust port, but an engine will run and not miss even without exhaust manifolds, so that would not cause it to miss. The only thing running without manifolds will do is eventually burn the valves due to the heat not being carried away from them through the manifold.
francoisc27
05-11-2008 19:01:16
 Re: A cylinder 2 and 3 not firing in reply to 658834, 05-11-2008 18:59:02
ih560 said: (quoted from post at 20:14:55 05/11/08)
This is confusing trying to run this topic down, Why is everyone replying in the main forum instead of under this topic?
It's probably my fault I am new to this forum stuff and I have no idea what I am doing. I apologize if so.
Francois
