Got it Started
Paul (FLA)
09-21-2004 06:42:53
first, made sure the fuel part of the equation was OK. Drained the carb, inspected the seperator bowl, checked the air filter for water, etc.
then checked the spark. Plugs were fouled, but no spark using the screwdriver test and even the plug against the frame test.
Checked the points, yes sparkage at the points, so finaly found a bad wire from the coil to the distributor cap. Cleaned it up, and that baby fired up. so happy, let it idel for 10 minutes, then proceded to get it stuck in a mud hole. HA
Paul
