How much time????
Brian of Arkans
10-03-2004 17:08:25
If I was to look for one with these repairs I still might get one with yet another problem. If I do the work myself I will know it is done correct and will not come back to haunt me.
I have found that my procrastination seems to be directly related to amount of effort and reward....grin. The easy parts are a breeze. The hard parts are a breeze the long term ones seem to be the ones that I procrastinate on. I am not proud of my patience. I like instant gratification....
I do not have enough money to spend several thousand dollars on a newer tractor nor do I have the patience for the long term project. I can handle three or four day repair projects but that is about my limit of interest...
I have found it is best to be honest with oneself as well when it comes to buying something that is the proverbial deal....
If it would have had a blade with it I would have bought it for sure. Since my need is greater in that area....grin Now I read that this 3 point will drif and require constant attention or yet another expense of a controller...
How reliable is this model once I take care of these basic repairs. Also any idea as to how much parts money I will spend on the 3 point pump repairs and the axel seal?
The axel seal scared me when I read tht one fella spent 1000.00 on having both of his done. I am hoping that was labor and materials????
Mr Chapp
10-04-2004 19:42:52
 Re: How much time???? in reply to Brian of Arkansas, 10-03-2004 17:08:25
Brian...Let me jump in here for one min.. I paid a great deal more for my to20 and I'm still happy. My left axle seal still leaks. The right brake works well, so I ignore it. My alternator doesn't charge, so I trickle charge the battery until I get around to re-wiring the whole thing. We can go on and on, but the end answer is that the little tractors are very forgiving and really hard workers. For the price I'd highly recomend it!! Good luck, have fun!! Mike
Brian from Arkansas
10-04-2004 06:47:46
 Its not a lot of money . But............. in reply to Brian of Arkansas, 10-03-2004 17:08:25
I am very greatful for all of the input.
I guess the last part I will describe is the conditions of which the item is being sold. I know this individual is in great need of money and is not selling by choice. As a matter of fact I am pretty sure he will take less if I bring to his attention the cost I will incur to make the repairs. (I would kinda feel like a smuck beating a person in need, out of money though) Therefore I do not believe that he is selling due to a known needed critical repair that the tractor needs. But on the same token I am pretty sure he performed NO maintenance on it either????
The only implement he has is the bush hog so I know all that he has done with it was bush hog..
Just for my piece of mind I will ask him if I can remove the inspection plates and spend some time looking it over. If he says no I will simply offer seven hundred as is and take my chances. If he counters I will accept any counter up to eight hundred. If he refuses then I will walk away and wait for one with a loader and spend the extra money when that day comes....
Jim W
10-04-2004 05:07:37
I have to qualify my remarks up front by saying that my experience is with the similar but not identical TEA20.
The axle seal could be quite a bit of work to replace. The early ones (of my model) required pulling the axle and hub (easy) and then removing a shrunk-on collar that keeps the outer bearing in place (pain; requires destruction of collar). Then after the bearing is off (pain) the seal can be replaced (easy), as it's outboard of the bearing. Assembly is not the reverse of removal - the new collar is heated to expand it and then "easily" slides down the axle to its location.
Maybe this could be one task that you could do, then take a break till your patience returns...now on mine I have not done this job as I don't need excellent brakes that badly; I live on flat land and can step on the pedal really hard, and I don't feel like doing this job as for the forseeable future I have better things to do.
Hydraulics though, you would need to attend to. I would call them an interesting learning experience. Between ~probably~ not needing any seriously expensive parts, and not being complicated, if it were me I would take a gamble and consider hydraulics the reason for the low price (again assuming I did my natural thing and pretended to myself that it wouldn't take as long as it most certainly would). You can get the various parts used; there are a number of wreckers around. This would be "test your patience project #2" (although you would need to deal with them first).
The rest is easy stuff. The bush hog vs. blade is a red herring. You can get a used blade quite inexpensively, sell off the hog, and come out ahead of the game. (More time and hassle of course, but, dollar-wise.)
Just a note about the drift of the hydraulics requiring constant attention - this only applies if you need to keep an implement a constant height above the ground. I have found I never need to do this. For any blade work I have done, albeit it hasn't been much, I wish the blade were heavier so it would bite more. The other main thing I do is blow snow and the blower rests on the ground for that as well.
Jim
PS How reliable once done? I think you will find the consensus on this message board is "very".
Norm in Ont.
10-03-2004 18:04:12
Hehe I was posting as you were replying. Nevertheless Brian I am in doubt if you should even consider purchasing it based on the patience limit you indicated. I mean this is a fifty year old piece of fine equipment where some half that age don't even start which should answer to its reliability.Expect your 3 to 4 days limit of patience work to be put to the test. These units will more than reward the effort put into them but may not be your thing.
Sorry to be upfront, my bad to be honest.
You can definitely consider exchanging the bush hog for a blade if that is what you need most.
As for the seal repair Jim can correct me on this model but my TO 35 has two seals per side and when I purchased the tractor it was leaking on both sides. I decided to change the outer seals only and this has corrected the leak. The inner seals are quite more difficult to change if needed but it is another story too long for this post.
My cost to replace the axle seals? $15.00 and a days work.
In a nutshell the whole forum here are a whole lot of people like you and I that are much satisfied with their Fergies and love to keep them in shape so they can probably operate for another 50 years.
Good Luck Brian
